56servi
I am finally reinstalling the far rear side panels in my 31 S/W. On the inside of the panel there is a metal bar about 1" wide screwed to the panel at the bottom. At the top is a slot that lines up with a screw hole on the window riser panel. The screw that was in there is a oval head screw.
Does this panel just hang on the screw?
The oval head doesn't go thru the slot in the bracket, but I am not sure it is the correct screw.
Its been too long since I took the panels off & I don't remember.
