56servi
I removed the 2 right front door hinge pins because of looseness in the hinge. The body is at paint now so the complete hinge sets were removed. I was able to press one pin out using heat & the "C" style pin removal tool. The other pin would not move so I had to drill the center of the pin out & then use a drift punch & hammer.
I have looked at a lot of the post on pins here but still have a few questions. I can get new pins made up at my friends machine shop. The top & bottom hinge holes are still tight on the pins. The center hole is worn & out of round. I saw a post here about a bushing for the hole that was sold on ebay but can't find it now. I also want to install rear view hinge mirrors on both sides.
1. Anyone know anything about the replacement bushing & will it work on Slant window hinges?
2. How much bigger should the center hole dia be then the pin. The pin I removed was .280 dia?
3. How long should the pin be for the mirrors?
4. Should I make the pins out of stainless.?
