31 roadster water pump help
sphooch
Hi guys , need some strong advise here . how can I stop the water pump from leaking without removing it from the car.?? I see split packing rings for sale but I never installed them. the manual only shows how to rebuild a pump. can I just add the packing ? please advise . thanks THE HOOCH
It isn't a hard job to remove the pump and give it a complete going over, but you can also just unscrew the packing nut, then use a dental pick to remove ALL old packing and install the new split lead packing rings. Use lots of grease on the packing rings and stagger the gaps half way around. You'll need to run and snug the packing nut a couple times during the first hour, but it only needs to be snug, not dead tight.
thanks for the help on the water pump guys. I'm gonna try the split packing , I can get my order in today. thanks THE HOOCH
