'31 Roadster p/u top question
JaxFLG8r
Working on getting the top on the '31 Roadster pickup we are putting together.
Bought the Cartouche top with plastic back window. I need to obtain the "studs" that go in the top of the back panel to hold the bottom of the top down. This top does not have a center flap that can be pulled up. It appears the holes in the cab are threaded. What is the proper name of the "studs" that I am looking for, and are they readily available from the typical Model A vendors?
They are not the "Lift a Dot" fasteners, just the open holes. Thank you. DEW
Here is what I have on my '31 RDPU. I put them in 40 years ago so I can't swear they are correct or why I chose them. I would try Le Baron Bonney, (800) 221-5408.
Charlie Stephens
Tony Hillyard a fellow Barner here. Made a YouTube video on Model A top installation.
Do a search for that. Very well done, as well as informative. Good luck. Jeff
Thank you all very much!!
Charlie that looks like exactly what I need, thank you for the picture.
jthomas6 thank you for the correct name. I found them at Snyder's.
I don't own a pickup but take a look at these Cinch Studs from Snyder's and see if they are what you are looking for.
http://www.snydersantiqueauto.com/cinch-studs
