Radial tyres get hotter than conventional ones because of the flexing that goes on as you drive. The tube rubs the inside of the tyre when this happens so obviously, if there is minimal friction between the two, they will run cooler. I use a little talcum powder on the tube before I assemble the wheel. By "a little", I mean just a dusting over the tube each side with it laying on he ground, then spread it evenly over the tube using my hand. I have seen the type of talc athletes use to get a better grip used - WRONG. Baby powder is the one to use.
