1932 V8
- City
- Windsor
- State
- CA
- Price
- SOLD
Sold
SOLD
Here is what I have for sale. Included is everything you see in the pics. Assembled Model A bed from Last Refuge with a non script tailgate. The cab is in decent shape but it does have rust around the lower portions of the cab and cowl.There is some patch panels included see pics.The firewall was drilled and removed but it was removed right and is bolted back in.
Front/rear glass has no cracks but the door glass is missing. There some small holes in the bottoms of both doors but none on the lower skin.
Boxed,blasted and squared A chassis with a 3" kick in the rear. 40' Front drums on a rebuilt stock beam with rebuilt springs front and rear. New bushings/pins along with new tie rod ends on 36' split bones.
Ford 8" rear . 40 Ford wheels with Lester 6.00 tires. The rear wheels had the centers cut out and a 5x4 1/2" center welded in .This was done by an old guy saving a buck. He used them for many years but I am not sure if I would use them as more than rollers .The tires have great tread but the white walls are weather checked.
T-5 5 speed with a Bond adapter and A pedals.This is setup for a V8 Flathead .
This project is rolling but still needs much work. Has many of the best parts already there, just waiting for some fab work and assembly.
Also available with the truck is a running 59AB .It was pulled from a 46 Ford that was street rodded.It has Offy heads,Offy 4 bbl intake w/600 holley.Basically a complete running engine as pulled from the 46 .The Engine is $2500.Firm
Great project for a hot rod build. Please ask me anything if you are interested .
$3300.00 obo for the truck
$2500. for the truck with out the T-5 trans/adapters
Thanks , Mike 707 217 8751
SOLD
