31 Locking Door Handle Shaft Dimensions
JohnB15632
Can anyone out there in Model A land be able to tell me the dimensions marked in RED ?
There is no vendor supplying the locking door handle manufactured per the attached.
Thanks,
You'll likely get your answer. If not, I can get those tomorrow afternoon when I return.
I'll stay tuned to see.
Overall I see 1 3/32"
For the first measurment inward I see 9/16"
For the next inward area I see 7/32"
For the third dimension I see 5/16"
However, there are irregular chamfers, crimps, and wear spots on the shaft, so these #s have some 'slop'...
BTW, Do the repops have a spring mounted inside the handle that allows the shaft to 'flex'?
Thanks, John
any of these work?
