Hi
Can anyone help in deciding which way to go concerning repro. fenders,how bad are the reproduction 31 Model A front fenders, I'm looking a purchasing a set but a bit worried about the fit, I know the dies are pretty well worn out and will need a lot of work to fit correctly, but at least you are starting with something that isn't weak from rust or the metal is fatigued from time or is it better to find a set of used fenders and repair what has to be repaired, has anyone bought a set of repro. fenders lately is the main shape still there, are they still worth buying or just get a good set of used and work from there.
Thanks
Russ
31 Model A
90% steel 0%rust 10 % fiberglass (both front fenders)
Thanks
Russ
31 Model A
