fordcragar
Not wanting to hi-jack the other thread:
http://69.61.21.195/forum/showthread.php?t=10373
My coupe window creeps down when it is all of the way up. At first, I thought I'll move the crank so it is in the down position, but this didn't fix the problem. In fact, with the window up you can press your hand against the window and with down pressure against the window pull it all of the way down.
So, it looks like I'll need to replace the regulator, unless someone has a fix for the problem.
My question is who makes a quality regulator replacement?
