RustyWiring
Hi folks,
I have another issue with the new hobby and would very much appreciate your input: Truck starts quick and easy when stone-cold. Runs great, driving as long as I want. However, if I turn it off and try to restart, it will not restart without choke; and, even then, it's a challenge to re-start. Once re-started, it idles and drives great.
This began, like a light switch, about 30-40 miles ago (I'm at about 130 miles now). Before that, just a touch of the starter and it would re-start. To me, it seems like an obvious carb issue: not enough gas or too much air. I checked and tightened every bolt in the vicinity (manifold and carb). No joy. I had my son remove the lower carb half and clean out the jets but that made no difference (assuming he did a proper job). I removed and blew out the idle jet today. No change.
I will be removing the whole carb and examining it tonight. For the experienced, this seems like one of those 'Oh, yeah. This is your problem...' problems. Any ideas where to start?
Thank you!
Thank you!
