Making some modifications to the front end of a 31 Victoria. 32 grill shell and hood which was bought new with and is 4 inches longer. I need to gain 11/2 - 2 inches between my headlight bar/grill shell/insert clearance. Have a 32 headlight bar with the cast iron bases and stainless center rod. I can heat the cast and bend it forward but this will most likely screw up my headlight bases. Any suggestions gaining the clearance or is there an after market bar. Don't plan on a dropped headlight bar but could if necessary. Any comments would be appreciated. Jim
