Actually the firing order on an 5.0 HO roller motor is 1-3-7-2-6-5-4-8. But, a standard 5.0 roller such as a pickup or crown vic is still 1-5-4-2-6-3-7-8. Also, if it still has the original roller timing cover, there is no fuel pump provision. If you are still in doubt, pull the distributor, roller cams use a steel dist. gear, flat tappet cams use a iron dist. gear. One more thing, a later roller block can still be used with conventional lifters
