302 identification help
50fordcoupeman
My avatar has a stock 302 in it. The characters (D1357) cast behind the starter indicates it is a 1977. The part number on the dip stick indicates it is a 1985. Is there any real way to know the year of manufacture of this engine? Probably a mish mash of parts. It doesn't really matter at this point but it would be nice to know. Thanks guys!!
I guess you could compare date code casting numbers on the block, heads and intake manifold. If the same year, then bingo. If not, a mix of different model years.
Sal
Sal.........yes it has a rear sump.
Rotor.......yes that is the casting number so that indicates a 1971. I was told the last digit was used not the first so I was told wrong. This makes sense because I got a replacement starter for a 1977 and it would not go into the hole by just a smidgen. That is what started my original question.
Thanks to you both!!
Coupeman, Darrell is the one that mentioned the rear sump oil pan, so he gets the credit.
Sal
I was used to seeing the front sump pan for years on SBF engines. Some configurations have the two bump configuration due to chassis design like the fox body Mustang & Capri as well as some of the trucks. They can use either sump but the oil pickup has to be changed to match the sump used if I remember correctly.
