302 ford water pump help
john mullen
Ok hear is what I have ....
timing cover .RF E3AE 6056 AB.I think to be 1983 302 full size auto...
The water pump is aftermarket aluminum unit with driver side inlet.it fits 70 to 78 302
its all going on a 1986 302 short block
My question is this
Is the timing cover for reverse flow water pump???
if it is... can I use a non reverse flow water pump on it 70 to 78
when did reverse pumps first come out ??what Year
I NEED EXPERT HELP ....PLEASE...Thanks John
Reverse flow is identified easily as the pump being driven from the back side of the serpentine drive belt. This was usually the 5.0L HO. The 5.0L STD used the normal rotation (before serpentine).
