51504bat
Putting in a 302/AOD combo in my '54 Ranch Wagon. The donor engine had a carb and a mechanical AOD but it had an electronic distributor. I want to replace it with a stock type point distributor. My problem is that the electronic distributor from the 302 has an about 1/2" longer shaft than the point type replacement that I have. The replacement distributor does engage the oil pump drive shaft but only by about 5/8" or so. This to me doesn't seem like enough engagement. Anyone have any suggestions for a stock type point distributor that has the longer shaft like the electronic one I want to replace? Thanks.
