Bored&Stroked
This is an engine that I've just completed - as a project to mentor a friend (Andy Huck) on how to build a performance street flathead for a 50's style Hotrod. He has an original 32 Roadster that came from his Uncle - which is where the engine is headed.
After this brief run, we installed a radiator such that we could break-in the CAM and run it for 30 minutes.
I put a bunch of work into resurrecting the Harman Collins dual coil, so I wanted to ensure everything was setup before putting the radiator on the stand. These old Harman Collins dual-coils can have a lot of issues with the secondary high-voltage yellow mid-plate - they want to leak the spark energy to all sorts of places other than to the plugs. I'm working on 4 of them at the moment - I had to do some "mods" to the plate on this unit to get it to fire correctly on all 8 cylinders. Thank gosh I have a Sun distributor machine with a 'Frankenstein' adapter to test the spark plugs - otherwise the chances of getting one to work correctly would be slim . . .
Enjoy the video!
https://youtu.be/u_5RrwzT2tc
Enjoy the video!
