This is for another time, another problem, but it's good to know. A couple of weeks ago, I was having similar symptoms and it turned out to be old gas tank rust. A plug in the carb intake, a plug in the fuel line. a plug in the sediment bowl and a plug in the shutoff valve. But not much in the sediment bowl. That's what kept me stupid! I couldn't see much in the bowl. When I finally decided to go after a fuel solution, I disconnected the fuel line and the gas did not even drip out. So I figured it was empty and I put a little gas in the tank. Still nothing,,,,,, Hmmmmm This means something! When I got all those little plugs out of the gas supply, trust me, it made a difference. What I didn't know was that those rust plugs could jam everything up like that and still seem like rust in the tank was not a problem. There was not enough in the bowl to indicate what was really happening. BUT the shut off valve was getting hard to turn. It was scored and all crapped up when I took it apart. Before reassembly, I lapped the two parts in the drill press, now they're sealed and they work a lot easier.
Terry
