Duke - one thing to be careful with is that the output side of the gas valve is a flare fitting, it's not a standard SAE straight thread. I've not had success finding a "hardware store" solution, rather just buy the right gas line from the suppliers.The tank threads are ¼" pipe thread. Sorry I don't remember what the fuel line is off the top of my head.
Further to YB, technical names for the input side thread is 1/4"-18 MPT (male pipe thread) or 1/4"-18 NPT-M (National Pipe Thread - male) for the fitting, and 1/4"-18 FPT or 1/4"-NPT-F for the tank.
JayJay
No, I just wanted to emphasize the different thread standards. Wasn't trying to clarify for you. I've seen more than a couple of folks screw a 1/4"-20 SAE into a 1/4"-18 NPT without understanding the difference. It will start but then when it gets tough they just keep turning and totally screw up the fitting. Not something you want to do on the bottom of the fuel tank.Haha, Have you ever seen a ¼" pipe thread that wasn't ¼-18 NPT? I don't need no stinky technical names...![]()
Further to YB, technical names for the input side thread is 1/4"-18 MPT (male pipe thread) or 1/4"-18 NPT-M (National Pipe Thread - male) for the fitting, and 1/4"-18 FPT or 1/4"-NPT-F for the tank. If you are going to use a tap to clean up the threads in the tank be careful you don't overdo it, with a tapered thread the farther you go in the bigger the hole, and you may inadvertently make it too large for the valve to properly seat. DAHIK.
Don't forget to put a screen into the gas valve before reinserting it.
JayJay
Duke - Others have very ably preceded me, but:Thanks Jay Jay. So the thread into the tank is 14-18NPTFine and the output to the gas line is 1/4-18MPT, male compression end ? Knew they were different but couldn't recall without a valve or gas line on hand.
Ok I can make out 5/8-18 US fine. So I found this valve cut from the vendor's catalogue and have placed dimensions in order to chase the tank threads.
Concur. I've found over the years in many pipe thread applications that "chasing" a female tapered fitting with a tap results in an oversize hole, and the male fitting threads in too far. Many folks equate "chasing" with "cutting new metal". If you cut new metal with a tapered tap you are increasing the diameter of the hole. If you do choose to "chase" a tapered thread hole, be sure to do it very delicately so that you are only cutting rust or paint, not enlarging the hole. Some time in the last 90 years someone(s) did that to the fuel valve seat in the tank of my pickup, and the valve bottoms out in the hole without sealing tight. Needs liberal doses of thread sealant, and frequent replacement (the sealant, not the valve).I don't want to sound like we are ganging up on you as that is definitely not my intent, but look at the print above and I think you will see that it really is not smart to "chase" the tank threads unless you have the proper tap ...which Ford used a different thread pitch than what I think you will find in taps today. I have experienced many gas tanks that had the threads cut oversized due to an incorrect tap size.
