"30 Tudor with OHV B engine
Herb Kephart
Glen Mills
PA
Price
18500 obo
Straight all steel body, off frame rebuild. Engine Ford B with counterweighted crank, drilled for pressure and balanced. Block and rods have insert bearings. Runs 50 psi oil, and has full flow filter. Original Miller-Schofield OHV head, aluminum roller rockers, FS ignition. Original 3 speed and 4.11 rear, but has Torque tube O/D. Mechanical brakes with Ted's floaters on '32 front brakes
need flatfender Jeep wagon or panel trk BODY ONLY
Questons? e-b-t-m-3-@-v-e-r-i-z-o-n-.-n-e-t (remove dashes)
Or 610 four 5 nine 2 one 7 seven after 8PM Eastern
