Petty Cash Member Mar 4, 2011 #1 Will a 30-31 steering column bolt right in and mount to the steering column bracket on the tank in my 29? Thanks, Tim
Tom Wesenberg Well-known member Mar 4, 2011 #2 Yes, there are small changes in the spark and gas rod lengths, but if you mean the complete column, then it should fit fine.
Peter J Well-known member Mar 4, 2011 #4 I did exacially the same thing on my 29. No problems. I assume you have a keyed steering wheel for the shaft? Pete
