30 pickup cab patches
metalho
Well the rear of the cab is patched, little harder than I thought but at least it done. Im happy with the results.:)
Just Curious did you just stitch tack the back panel across the back? It doesn't look like the seem is welded.
Thanks for posting. I was just explaining to my wife, how a patch panel would work on my Mullin's trailer. Your timing couldn't of been better.
Paul
i used machine screws and nuts to keep the panel levle and in place corners on first than center also only used as much patch as needed as far as how tall the patch used was that kept the taper of the corners correct since the corner patches ar not the correct taper so i used only what was needed
Rollingsculpture, Do you have any pictures of the rear body cross member, the piece between the seat pan and the back of the cab, fitting and installation?
Bob
heres the details
