I removed the rear spring from my 30 coupe today, both side shackles were bad, and need replaced, to my suprise its a 10 leaf spring. (accourding to my snyders parts book coupes phaetons cabriolets a400 and victoria should be 8 leafs). Applied a "C clamp" and cut off the center bolt. no broken leafs and not much ware on the ends of the leafs from friction.
So should I paint it and reinstall, should I remove two of the leafs (which two, or buy a replacement spring. The measurements from the center of the eye to eye is about 39 3/8", measurment from ground to top of spring at center bolt is 17 3/4". measurements taken prior to removal of center bolt.
I know i have the correct measurements for the spring in a relaxed state someware, just haven't been able to find it yet. You guys will most likley respond to this post before I do.
Thanks
Happy New Year to all!!!
Thanks
