30 closed cab pickup windshield
metalho
Ive got Les Andrews I & II books, and a stack of other restoration books but cant find anything on front windshield info. Have new glass, screws and rubber but nothing to help me put it together. Any links out there?
Hope these will help let me know. You have to pry up edge to insert. flatten back out over rubber. don't stretch it let it do its own thing as you install it .45' corners. the top has the bead outside.#2 is from outside/top,#4 looking up from bottom,#5 red is outside. Don't forget the Swap Meet Sat Monroe. My email is formhals@whidbey.com. You can also slide in takes time with some vasoline on rubber.
Cant thank you enough Gary. These are great! I lost one of the edges on the side from rust, but Im think I can carefuly spot weld some tabs that can be folded over the rubber. Again, thank you.
