Curtis in MA
My brake pedal does not return all the way when stopped so I first disconnected all the rods from the cross shaft and removed the brackets to see if the bushings were worn. They looked fine so I reinstalled the brackets.
When I rotate the cross shaft forward by hand, as if the brakes are on, the cross shaft hits the radius rods.
How much clearance should there be from the CS to the radius rods?
How much travel should there be in the clevises?
