30-31 pickup cab parts
Mike/Nebraska
Does anyone know of a manufacturer that makes replacement panels for the back of a 30-31 cab? Either the entire cab back or from the belt line up. I see them for a 28-29 but never a 30-31. Mine had a sedan rear panel and the belt line doesn't line up. Thanks, Mike
No one makes a cab back that I’m aware of, only the corners and the patch across the back down low. I’m surprised they aren’t reproduced, there’s lots of tudors that could be converted that way
Mike, as mentioned above, there is not anyone commercially making that panel. One suggestion I would make for you is that a friend of mine in Hastings, NE (-not sure how far that is from you) named Pat Brubaker offers metalshaping classes for hobbyists. Pat is a great shaper, and he has the equipment to assist you making the panel you need. If you need his contact info, PM me, -or you can probably get enough info off of these two links below to contact him.
http://www.hastingstribune.com/news/sheet-metal-shaper-teaches-hobbyists/article_481879ac-149a-11e7-85c7-7baf4eb37890.html
https://patman1.tumblr.com/
Howell's makes this panel. It's the lower half, not what you need but the biggest rear truck panel out there.
