30-31 brake lite switch
I have a question about how the 30-31 brake lite switch works. If I mount it in the correct location at the rear of the main crossmember, the brake operating rod is approx 1 inch forward in front of the switch rod.
If I turn the switch around the other way which will pull instead of push, will this work the same way operating the brake lights when the brake pedal is pushed using a special rod or chain to pull the switch?
Appreciate any help from the Barn.
Speedster Jim
Don't turn it around. We need a picture to see why it's coming up short. Is the brake pedal returning all the way up near the floorboard?
You should have 1/16" gap with the pedal all the way up. Check your brake adjustments per the service bulletins.
From the Ford service bulletins:
"......pull the brake pedal all the way back until it is against its stop - then adjust the rod until there is about 1/16” clearance between end of rod and rear flange of center cross member (leaving a little clearance between end of rod and cross member prevents any possibility of the end of the rod rubbing against the cross member and causing a squeak).
"After adjusting the brake pedal to cross rod, assemble side pull rods to brake operating and cross shaft end levers. When assembling the side pull rods, pull the brake operating levers on the front axle back and the brake operating levers on the rear axle forward (taking up all idle movement). Then with the levers in this position adjust the side pull rods so they can be assembled to brake operating and cross shaft end levers.
Next adjust brakes by turning up the adjusting wedges as described on page 202 of the January, 1928, Bulletin. After the brake rods have been correctly adjusted car owners should be notified that this adjustment must not be altered. Service brake adjustments must be made only by means of the adjusting wedge at each brake."
From page 202:
"Make all adjustments with brakes cold. Jack up all four wheels. Release hand brake lever. See that wheels revolve freely. Turn the adjusting wedge at each brake (not the pull rod) until the brake drags, then back off the wedge 2 or 3 notches or just enough to allow the wheels to revolve without drag. On new cars brakes will sometimes drag slightly for ¼ or ½ revolution, due to slight high spots. Some judgment must be used in setting such brakes, for if the adjusting wedge is backed off sufficiently to allow the wheel to revolve freely, the brake pedal will go all the way to the floor board when the brakes are hot. A slight drag in one or two spots will do no harm, as the brake will soon free up when the car is driven a short distance and the brake drum slightly expands due to the heat generated. For this reason, brakes should not be adjusted with the drums hot, as when the drum contracts upon cooling it would cause the brakes to drag. To insure correct equalization have one man only check the brake pressure by rotating the wheel. If the above adjustments are correctly made the brakes should operate as follows:
1. Rear brakes should just start to hold when brake pedal is depressed approximately 1 inch.
2. Depressing pedal about 1/2 inch farther should tighten but not lock rear brakes and cause front brakes to just start to hold.
3. Depressing pedal approximately another l/2 inch should lock rear wheels and hold the fronts very tightly. With properly adjusted brakes this should not exceed one-half of the total possible pedal movement.
Thanks very much,
I will make the adjustments this weekend and report back on progress.
Thanks again for the through explanation.
Jim M.
