Todd in WA
I have a 41 Ford Pick up I recently finished doing an engine swap and put a flathead back in. This is a newly rebuilt flathead with new clutch.
The problem I am having is it will not go into reverse. All 3 forward gears are perfect but reverse will not lock in.
Everything was working normal with not problems, before the changeout and the trans was recently rebuilt. I pulled the shifter cover off and all the teeth are good with no chips or teeth missing.
When trying to put in reverse it sounds like it is trying to engage.
Could this possibly be a clutch problem instead of a ****** problem?
And yes, the truck is running and not moving when I shift it into reverse.
