Fatboy Tim
Men
Driving me nuts, flathead rebuilt and 3 speed gearbox (******) rebuilt in 32 coupe, all back in but can't get a gear. OK in neutral but when clutch pressed won't let me select a gear (loud grinding noise, not good).
Looking thru' inspection hole I can see the pressure plate moving but not by much.
Question is, how far should the travel on the lever be on the outside of the gearbox, mine moves from 12 o'clock to 11 o'clock, is that enough?
Some folks seem to cut down the lever by 1/4 inch to get more movement, anyone done that?
Thanks for helping.
PS Pressure plate is 10inch, I know thats not standard but its what came with the car.
Thanks for helping.
