Gold Digger
Has anyone installed 3-point seat belts in a tudor and if so how did they mount the top mount? It needs to be a strong mount.
I saw someone so proud of their seat belts in an A. Made a bracket that mounted to the frame that the seat belts fastened to. I guess I'd not like to be in a wreck and be the piece of meat between the body and the frame, as that's what he had made himself. Most of the contraptions I've seen make me happy with my no-seat-belt A. I'm not against them, but just make sure they are well thought out. (maybe a fighter jet ejection seat?)
It can not be done unless you are willing to do some extensive frame modifications and add a roll bar.
Model A's were built before crash safety was invented and have NO basic features for such.
Every thread about seat belts seems to attract at least one person either explicitly or implicitly arguing that no seat belts is safer than seat belts attached to the frame. I would like to see these people produce actual evidence instead of speculative ideas of physics. If you have seen actual accidents, what were the injuries? Were there belts and how were they designed? Was the body separated from the frame entirely or partially, and where?
This kind of theorizing has real-world consequences.
I put seatbelts in my tudor to basically keep me in the car incase the doors pop open I stay with the car. I think that you are basically on your own when you are involved in a high impact accident in these cars.
The entire anti-seatbelt argument centers around the idea that seat belts seem safer than they really are, because people are accustomed to modern safety systems, which require the whole car to be designed for occupant safety. Let's explore this idea, because I think it breaks down into a few different claims.
I installed a four-point harness in my woody/huckster. All structure from the windshield back is wood. Belts are anchored to the floor with large bolts and backing plates. Wood is very thick lumber and I figure any impact that would pull these anchors out would be more than enough to crush the entire structure me included. The doors tend to swing open easily so I have installed backup latches. I did work in the auto racing safety equipment industry so I have a little knowledge. Putting in a four-point system eliminates having to attach to a "B" pillar, just go to the floor. I have learned to drive the A very defensively and installed very bright LED lights all around, short of putting a full roll cage I have done the best I can?
