I found a clevis to use on the front carb. So nowI am in the process of removing the original manifold. Between "Honey do's". Yes any advice on tuning is much appreciated.
Where can I tap in manifold vacuum for the distributor?
I see that the heat tube for the choke is on the drivers side now, so I made a longer insulated tube and ran it between the #1&2 carbs to reach the right side exhaust manifold.
Adapting the firewall mounted throttle will be fun ! There is a kickdown rod to the transmission that has to work.. hmmm
These carbs are supposed to be remanufactured. They are beautiful,,, BUT I do see a little lateral motion in the throttle plate shafts. I know from experience that it screws up the idle mixture.
