gmcbuffalo
I have a 1935 engine with a three brush generator with two wires coming out of the casing. One wire is grounded to the case and the other to the
ARM side of a helmet metal box with a second terminal labeled Batt. I have learned that this is an after market generator. This is based on the front mounting bracket. The bearing as an seal come out the front with a large screw in disc that goes over the armature shaft. The original Ford generator the bearing were inserted on the inside and held in place by a clip ring.
I have a Ford's repair manual of generating and starting systems. my confusion in checking out this generator is the manual keeps referring to Field and Arm terminals. I know there has to be such things but I only have one wire out side of the ground.
I want to check out the armature by connecting the field to Arm terminals and then batt neg to Arm to see if the generator will motor.
GregM
GregM
