flathead 39
Currently constantly looking for another gear when driving my 3.78. I'm sure I have enough power for the 3.25, but will have to use 1st & 2nd gear a bit more.?? Any advice appreciated.
What top speed are you wanting?
What size rear tires are you running?
I know! It's ridiculous but that's all they sell now.. even so called vintage gauges.I can't answer that for him, but his speedo does go to 140 mph! DD
Gas mileage, noise, & the feeling that there needs to be another gear. I drive her a lot.What top speed are you wanting?
4:11 in my '36 Phaeton, the engine screamed at me over 55. Switch to 3:78 and the same configuration is ok to 70.
So where is the 3:78 letting you down?
The 3.25 will lower your RPMs at 55mph to 2145. I think it will take it to make a significant difference. Then you might have difficulty getting rolling. That can be helped with pick-up transmission gearing. One thing leads to another.
How much motor do you have and any towing or major hills to deal with ? Ive got a 41 tudor with 378 and have been working on a 354 dif this week . I too have been thinking about changing . 378s down here in Florida are decent but always looking for more also .
Here's a link to a calculator that I used a lot to figure out my gearing/speed/rpm. You'll need your tire diameter as one of the factors. My 40 Fordor came with a 4.11, talk about screaming at 55, that lead me to buy a Mitchell OD, ends up an equivalent of a 3.10 +/-
I don’t think the 3.54 would make enough difference for you but the 3.25 would. Others with a 3.25 will know.
http://www.advanced-ev.com/Calculators/TireSize/
39,
When you mentioned 1st gear for you is almost worthless made me wonder if you already had the 15/29 first gear in the trans now. Obviously third is still one to one
so high gear on the road won't change. The motors in my '32 and '41 pickups are near
what you are running and first gear for me is very worth while ,both trans have the 16/28 gear set.
The cam in my '32 makes power above 3000 rpm and the drivability went to hell when I changed to 3:78's from 4:11. Something to keep in mind as the rear gets taller.
I do have a Columbia with 3:78's in the '41 and in OD I think the ratio drops to 3:22
or somewhere close. The Max 1 cam has no problem motivating in OD.
Charlie ny
