Hi, I'm new to this site. It's great! So I have a 52 Ford with a 53 Merc flathead. This motor came with a tea pot carb, which I purchased re-manned and bench tested before I installed it. I was having a lot of hesitation, bogging down when acceleration. So far, I've changed out points and condenser, distributor cap, coil. I had a problem with older spark plug wires, and changed all those out yesterday. Specs call for BTDC 2 degrees. Since there is no marking on block for above and below TDC, I've adjusted a little at a time going both directions. In first gear, I can accelerate with no issue, 2nd gear it boggs down at higher spead. 3rd gear no issues. I've moved the jets on the carb to recommended 1 turn out. Any suggestions?
