Ed Saniewski
My painter lost 2 of the hinges to my pick up
. Are any other hinges interchangeable with the 82-A? Thanks.
A friend pointed out that the rubber bumpers which the door window hits when lowered are about 1" higher in the T doors as compared to the A doors.
Soooo, I measured some of my doors. And, YES, my T doors have the brackets which the bumpers are attached to 1" higher than my A doors. The door window will end up sticking up above the garnish molding by about one inch.
My friend took the brackets off his T door and shortened them. He then reinstalled them (using bolts) so his door window now lowers correctly.
It seems that there is always something NEW to learn about OLD parts.
Attached are two pictures showing the difference in the location of the door sash rest for an 82-A closed cab and T door (about 13/16" higher).
Some T doors have the door lock on the outside of the inner panel. Some T doors have only one sash rest in the center of the door. Some T doors have a crowned belt molding. I don't know which body styles these T doors were used on.
