I have a one inch carb spacer with a large vac port out the back from a 351 2v ford. I am now running a 2100 motorcraft 2v carb on my 292 without a pvc. I like the carb and am wondering if I can use the spacer and put in a pvc in that flat spot at the rear of the valley pan. I would also build in a baffle underneath and also block off that road draft tube. The spacer fits the manifold perfectly so I hope this will work. Any help will be greatly appreciated!
