make sure you can turn the dist shaft with your fingers, remove cap and check centrifical advance weighs and springs, check the vacuum advance pot to see if the diafram is leaking and it advances the timing what im trying to say is check every thing inside the dist to see if all work, if its a good one you will see a difference in the performance of the engine, usually a 2 to 3 hundred rpm gain at idle, the best and cheapest h/p gain you can find, your going from a 25000 volt charge to around 50000 at the plugs with that dist, better fuel burning, more power
