292 312 Ford Engine
ncauclair
Hi
I have a 292 312 engine. It has a serial number on an original manifold as follows " ECE-9431-8 8 An odd looking "C" symbol with another symbol inside the C and a 4E 26. Anyone have any idea what year Ford the engine came out of? Also where would an engine number be located. Thanks Nick
Hi
The various parts of an engine (like that exhaust manifold) have their own casting numbers.
Some parts were used on different year & displacement engines and the casting numbers could carry on for a couple years until Ford saw the need to change them.
Not to mention parts from 'wherever' being swapped around in the 60+ years since then.
A misc info and casting number link...
http://www.y-block.info/main.html
The casting number on the engine block itself is the one to look for.
... where would an engine number be located. ...
There may be three different locations depending on the year and foundry.
Go to the "Block Identification" tab (with a few photos) at this link...
http://ford-y-block.com/technical.htm
The "CF" symbol is for the Cleveland Foundry, as opposed to the Dearborn Industrial Foundry "DIF".
The "4E 26" is the date code of when the part was made, 4 = '54, E = May, and 26 would be the 26th day of the month. IIRC
It has a serial number on an original manifold as follows ECE-9431-8 8
That will be found in the offered EXH MAN Casting I.D. CHART - ECE-9431-B
An odd looking "C" symbol with another symbol inside the C and a 4E26
The first identifies it as being cast at the CLEVELAND FOUNDRY and the second the DATE of CASTING.
The CASTING ID NO. identifies the EXH MAN as being a 272CI.
Wow. A great brain bank of knowledge. Thanks for all the info. So it's not a 292 312-- it's a 272. Cool. Big thanks.
... So it's not a 292 312-- it's a 272. Cool. Big thanks.
Did you find the actual engine block number? It will be 3 letters usually followed by '6015'.
Those ECE exhaust manifolds will bolt on to almost any other Y-block engine thru '64.
A 272 will have the letters "ECG" on the block, usually at the base of the distributor. Also the 'DIF' symbol.
It can be bored out .060" to make it a 292.
Those are heavy engines.
What ****** do you have with it?
If it is a manual that is a good thing.
The automatics were god awful heavy because it was cast iron case with cast
iron bellhousing.
Good thing if it has a 4 barrel carb and intake manifold already on it.
Hang on to that engine even if you just store it under tarp.
They do not grow on trees anymore.
It (ECE-9431-B ) identifies that particular EXH MAN only. You need to ID the rest of the components to actually know what you have. It just might be a 312 under there.
Too much guessing and too little fact.
I took a photo of the number on the block below the distributor. Had the Cleveland symbol and a 35 number. I tried to post the engine photos here but it won't let me????
