292/312 engines
I heard that very few '56 sedans/hardtops/convertibles actually got the 312, maybe something on the order of 15 or 16 thousand.
the 312 became an option in fords in april 56.in canadian fords and meteors in 56 a total of 24 were installed and of those 13 went into wagons.
DMSFFR
Thanks for the list
Now, if I find ECK or EDB-A on the block# can I assume that it's a 56 engine?
This all very confusing to a flathead Ford guy
Not sure my old brain can take this all in
Jim
Other than the change in displacement, what else is different/advantageous to a 312?
Better heads? Different camshaft? Obviously a bit more power.
Just wondering
Jim
.....and a block that likes to show cracks around the main bolts from overtorque and not enough material due to larger main bearing diameter. The best 312 I've seen or had has been built off a late 292 block.
I agree. If you want the best 312, start with a late 292 block. Get a 312 crankshaft and have the main bearing journals turned down to the 292 size.
Sal
