29 Windshield help
rinzana
Hello,
Getting back to work on my 29 Fordor. Need to change the rubber that hold the windshield in the frame and paint the frame. So far I have removed the top of the frame and hinge.
How do I remove the glass from the bottom part of the frame? Is there a trick or just pull?
Should I clean and paint the frame before or after re-installing the glass? Is there a trick to re-installing the glass?
Thank You
Rich
Once the top section is removed and to remove the remainder or all of the glass - use a block of wood, a large hammer and pound away. I did the task - the windshield glass is very strong, but it will come out.
