fred93
I think that I have read about every post that refers to the alignment of the hood on the 29 Tudor. And I am in the process of reading them again. I started to get into that purcedure today and I think that I may have more problems then I thought.
It looks to me like I will need to tip the cowl up a bit--but also it seems that the radiator needs to be moved to the right some what. (and I don't think that is possible unless I elongate the bottom radiator mounting holes)
I have attached some photos for you guys to look at and see what you think. If you need more photos let me know.
The body is all bolted down at this point. I had a slight problem with the pass door (looks like at some point the hinges were strung. I was able to tweak things somewhat and the door closes okay now.)
