Model A Ron
John Charlton I sure hope you see this....
I got my draglink and tie rod inserts today so I decided to install them prior to performing John's tip listed below What I found out once the draglink was off the car is the 4'' of play in my wheel is what it takes to get the pitman arm to move. When you wiggle the pitman arm from front of car to back you get about 1/8'' of play. When you move the wheel and hold the pitman arm that's the 4'' in the wheel. The play is there until you pin the wheel to the far left or right.
My question is the below procedure from John going to help me or is it time for a steering box rebuild?
You remove the 3 bolt diamond shaped plate .Put the steering wheel dead ahead . Remove the Pitman arm and push on the shaft until the sector just clears the worm . Rotate the steering wheel half a turn and push it back in and reassemble ,just that simple .
John in Suffolk County England .
