'29 speedo cable
my64gal
has anyone out there had an issue with an aftermarket cable fitting in an original housing? It seems like the little washer won't fit:confused:
Hi I recently replaced the inner cable on my 29 tudor. The repo cable had a flat washer near the square drive by the speedo head , but it wouldnt allow you to tighten the cable to the speedo. I cut the washer with a pair of sidecutters and presto.
My repo cable was too short so I sectioned it and used a piece of copper tube and some JB Weld to make it a little longer. Worked good.
