One door on my 29 roadster is missing the door guide clip, the rubbers, and it's supporting structure - ie, the sheet metal that holds the clip and it's rubbers in place is missing. Does anyone out there know a source that describes how this area of the door is constructed, so I can repair it?
There is a gap in the door structure (about 2 in) where the slot, door clip and it's rubbers should be. It appears I need to weld in a new support structure in order to install the clip and rubbers to hold them in place.
I have not yet removed the existing clip on the other door to see what it looks like as its not clear to me how to remove it without tearing things up. By looking at the other door, all I see is the clip and it's rubbers installed in a small slot in the door, all tucked behind the sheet metal. How does one replace the existing clip? Do you just pry out the existing clip and rubbers with a screw driver? Or is there a different technique that won't tear things up.
I'll attempted to attach a picture once I figure that out.
Any help or guidance is appreciated as always.
