Hung the doors this past week. Driver door aligned after a few latch adjustments and open/closes well. The passenger door is 1/2 inch low at the latch. My understanding is that the back of the cowl needs to be shimmed up. Problem is how. The body block is long running under the cowl and the door piller. Under it is the rubber body shim. How to lift and insert additional shim is the question?
Thank you for any ideas.
Tom
Tom
