ModelAHawaii
Hi,
My 29 pickup has no forward or reverse gears.
I lifted the rear axle on jack stands. Opened the fill hole on the of the center carrier banjo. When I spin the motor by hand the pinion gear and spider gears and the right axle (pass. side) spin. The left axle (drivers side0 does nothing.
I had my son spin the motor while I locked the carrier in the banjo. Nothing moved. I I believe everything from the engine to the drive shaft is good. When I try to spin the drivers side wheel nothing at all spins in the carrier. The pinion gear spider nothing.
I've pulled the hubs the axle keys are still good on both sides.
Is the drivers side with the large pinion gear the drive side of the rear axle?
If I have no foward or reverse gears does that mean the axle gear is broken or????
Are the rear axle halves with the gear one solid piece each? Again I'm the third owner so I don't know if anything has been done to the rear axle previously. However, where the original axle half solid one piece with the gear?
I've been trying for some time to isolate the issue of the now movement and seem to always come back the the rear axle.
Does anyone sell rebuild rear axles? Just drop in. I live in the middle of the ocean and don't really have anyone locally that works on the Model A's. I've been just doing most things myself since I purchased the pickup but this one has stumped me.
Any assistance would be appreciated.
Thank you!
Thank you!
