Dal's Dream Car
Mine are a little loose. I'm a novice mechanic but would like to tackle this one myself. Any tips, instructions, videos, warnings, experience, first aid advice, Hail Mary's or cash donations? Cover me! I'm goin' in!
New ones are not necessarily needed. Clean the old ones thoroughly and inspect for pitted areas. Hold the bearing up to sunlight and look at the inner race, between the rollers. Rotate the bearing to inspect all 360*. If packing by hand be sure that grease completely enters all areas between the rollers, and smear a coating on the outside of them and the cup (race). Adjust as Tom W. says, with no preload as the hub expands more than the spindle and when hot they have a slight amount of tension on them. I prefer good Ford Timken bearings to new ones that are often made overseas.
Here's a link to a long and detailed video and another link to a good written tutorial on wheel bearing replacement and adjustment.
They are oriented toward modern cars and therefore refer to discs instead of drums, but other than that nothing has changed in 85 years.
Joe
The video and tutorial both say to tighten the front axel nuts to 50 ft lbs, back off one full turn, tighten to 10 ft lbs and then back off one slot. 50 ft lbs to 'seat' the bearings seems like a lot.
The video is sponsered by Timken but is directed towards modern discs. The last thing I want to do is damage a new set of bearings.
This is how Ford specified wheel bearing adjustment in the Jan and April 1928 Service Bulletins
Adjusting Front Wheel Bearing
If there is excessive play in the bearing it can be adjusted as follows: Remove wheel. Withdraw cotter key and tighten adjusting nut until the hub just starts to bind. Then back off the adjusting nut one or two notches until the hub can be freely revolved. Before replacing the wheel, be sure to insert cotter key in adjusting nut.
Important Information on Front Wheel Bearing Adjustment
1. See that front hub, inner and outer bearings are packed with grease.
2. Front hub grease retainer and lock washer should slide over threads on spindle body with fingers (loose fit). the switch come in contact with any metal
3. Install nut, tighten same so that all component parts are pulled together snugly; that is, inner and outer bearings will be snug in cones, lock washer tight against roller bearing, and nut tight against lock washer. Grasp drum at top and bottom, apply side strain; see that bearings are tight in wheel hub with no side play. (A slight drag will be noticeable when drum is turned.) Not over eight or ten pounds' pressure is required on speed wrench to get these results.
4. Turn nut back two castle slots (this is approximately turn of nut); insert cotter pin and try bearings for a slight .side play and a free spinning wheel.
I've never seen a lock washer used on the front spindle.
You guys are the best! I have it apart and will order new ones to be sure. Good stuff, good knowledge & good people! Thank you.
