29 coupe top wood
This section is for questions on the site, not technical. Put your question in the Model A section.
I would use a polyurethane, flat if you don't like a shiny surface. Two or three coats, sanding after the first two coats for a nice smooth surface.
Drill all the holes you may need first.
