Racur96
Hi , I’ve read some post & the frame welting goes on the frame then the splash aprons. The front body block under cowl the rubber shins go between the bottom of cab & on top of the apron correct ? On The center & rear cab blocks are the rubber shins nailed to the top or bottom of the wood mounting blocks , if they went on top I assume the bottom would rub against splash apron or do you put a shim on top & bottom ? Or a shims on one side & welting or something on the other ? Thanks
