29 7 tooth steering column
stainless steve
Hi guys ..Ive gotten another steering wheel for my coupe and while the old one is off I want to change out the cup under the wheel and spark and fuel adjusting rods and what I believe is the quadrant part that the spark rod runs on because all the detents are worn off ...does anyone reproduce this part or is this something I need to get a hold of Berts for . I had the shafts and worm gears out and re bushed and sealed the column but now with a good wheel I dont want to pull it back off . This is on a 29 7 tooth column
thanks Steve:cool:
I use a triangular file to clean up the notches. It doesn't usually take much. I've discovered that the grooves are often just full of rust and crud, rather than the peaks being worn down.
OK ..I was thinking that might have to be done ..Ive got one super thin spot I will mig back up then ..do you paint it black like the column then or what was it originally
Thanks guys
Weld up the flats on the back of the control rods to obtain a good ratchet effect.
