Thanks, Craig.
I've been communicating with Matt (Dynamic Racing Transmissions) regarding their governor kit. It comes with 3 weights-11.5 grams, 12 grams, and 12.5 grams. The 12-gram weight provides WOT upshift at approximately 5800. Each .5 grams change will move the rpm up/down 200. Matt said that springs aren't included because they're not necessary. The housing normally comes with 12g weight installed, but you can request that the 11.5/12.5 be installed in the "Comments" section of the order form.
